Please I wish you can help me with a problem, I have a 2.0 2003 boxer, HDI, have a starting problem, excess of return by an injury, repair it, but the problem is that now they do not have the same strength, the slopes or straight, it takes a lot to take speed in the line
They have constant flickering, as the voltage goes up and low
The EGR is the main cause of these problems in Peugeot you must linked it, it is a factor that causes that symptom not the only one but it is what generally fails, liniandola test and you warn how it goes.
