RENAULT 19 DISTRIBUTION CORREA INCREA
15 years 1 month before #13766 by manual-mecanica
Manual-Mecanica Answer on the Re: Putting Renault distribution strap
:) As you are again, thank you again for answering the car I do not have the only thing it has is that module of ignition Siemens is large of aluminum and it comes with the built -in coil with respect to the gas and led to review and they tell me that everything is in order and I tell them then because if this one does not want to start me they say that the problem is mechanical and I answer them mechanical or electrical New Conplete because two or three had leaks and I thought that it was the incoment of why it failed and accelerated but when assembling again it continues with the failure I thank you your advice I hope if you find the fault in your car reports to what caused it is:( rare it never happened to me since I am in the item hahahaha and good that it will: UNSURE: be:) B)
15 years 1 month before #13768 by manual-mecanica
Manual-Mecanica Response on the Re: Putting Renault Distribution Still 19
Hello and look at mine with my brother we are making an adjustment, when it is ready I take the comprehension and igniting rates and I pass them to compare them, with the carbu if the problem is happened, if I look good in all aspects I pass all the set to you to try :)
15 years 1 month before #13769 by manual-mecanica
Haaa forgot, mine has a computer that controls ABANCE Tenperatures cooling of the admission and heating of the admission and barios more sensors, and has a card for Scaner. But the engine is the same R19 RT 1710 CC Mod 93 Frances
15 years 1 month before #13773 by manual-mecanica
:) To look at this car you must also bring it if it is French and it has the same engine you could facilitate where it is located is where the fucilera is or elsewhere especially layers I did not realize it would thank you if you can tell me where you have it in your car thanks : Dry: :)
15 years 1 month before #13861 by manual-mecanica
:) Hello, how are you going to tell you about the doubts if T6e served was the module no more what caused the problem was what I thought the module beyond giving the exitation to the coil so that the spark is leaving is to see the progress of the car. The theme was that the spark threw but not at the right time and how is everything electronic spark at the moment later this more than the captor who carried in the EMBREAGUE later I see if I can send you photos of what was short inside the module greetings
