Delete service now
15 years 1 month before #13584 by manual-mecanica
Delete service now published by Manual-Mecanica
Hello, do you know how the Volkswagen, Seat, Ecta service is erased ???
15 years 1 month before #13588 by manual-mecanica
Manual-Mecanica response on the Re: Delete service now
1.- Press the right button of the picture without releasing it (to put the partial kms)
2.- Put the contact.
3.- And without releasing the right to go to the left button and turn it once to the right, with a touch as if it were put another minute on the clock. Everything is released and then the contact is taken again.
4.- The contact is put again and said warning disappears ..
www.audisport-iberica.com/foro/index.php?showtopic=64439
15 years 1 month before #13589 by manual-mecanica
House gift ...
A-3 ´97
. A Contact removed Press Right Marker button and maintain.
. Give the contact, when you put the right button.
. Strip of the Izquiero button for approximately two seconds.
In the last A3 of body 8L the left button instead of pulling it must be turned to the left, the rest the same.
A4 ´01
. A contact removed click and hold the central button (of the three on your right), put contact, release the central button.
On the screen the words inspection will appear, Service ....
. Press the right button and keep it until the screen letters are erased and a new interval appears.
. Remove the contact.
Opel
astra g
. With the contact removed click and hold the right button the score.
. Give the contact and the word INSP will appear for two seconds +-, already below ---.
. Then release the button and remove contact.
Peugeot
P-206
. Among the account clock and temperature there is a button, remove the contact and keep pressed.
. Put the contact and continue to hold for +- 10 seconds.
. A 0 will appear and the English key will disappear.
Seat
Leon
. A Contact removed click and hold the right scrub button.
. Give the contact and turn for a second that same button.
. The screen will be deleted, then release the button.
. Remove the contact and put it again.
Ibiza `02
. To the right of the accounting there is a button, with the contact removed and keep it. Give the contact.
. The word Service will appear on the screen, so you can already release the button.
. Turn the button to the right until it appears ---, then I will release.
Ibiza `99-02
. With the contact removed, press and hold the button on the right of the scoreboard. Take the contact and turn the bow to the right during +- 1 second.
. The screen will be deleted, then release the button and remove the contact.
Volkswagen
Golf IV
. With the contact removed click and hold the right scoring button.
The word Service will appear, then release the right button.
. Turn the left button for +- 2 seconds.
