Seat Cordoba Rear Antinieblas Rear Lights 1.4
15 years 1 month before #13586 by manual-mecanica
Rear antinieblas seat cordoba 1.4 published by manual-mecanica
Someone could tell me what is the number or position of the rear antinieblas relief of a Seat Córdoba 1.4
of the year 1999. It does not work for me, nor the light of enrollment or that of the trunk ............ Thank you ...........................
14 years 9 months before #15982 by manual-mecanica
Manual-Mecanica Response On the Re: Rear Lights Rear Lights SEAT CORDOBA 1.4
Hello, I think I have the same problem as you. I put the fuses of the rear antinieblas (nº 10) and the light of the registration (No. 3) and melt at the moment. In addition, the trunk light is fixed, it does not turn off when the trunk hood is lowered. Have you solved it? As?
Thanks anticipated: Dry:
14 years 9 months before #15986 by manual-mecanica
Hello, the reverse has nothing to do with the problem you have
on the rear door ... Look at the piece of cable section that
leaves the body and enters the gate sure that almost all the cables are cut ... a balance
14 years 9 months before #16064 by manual-mecanica
Hello again, because they were indeed the cables that go from the gate to the body, something incredible because they are involved in a rubber that has no other way to open that is not cutting but there are all the cables stuck and cut touching each other, they rightly jumped by fuses at the same time.
Thank you all especially Warni.
14 years 7 months before #16958 by manual-mecanica
Hello everyone, I just acquired a Seat Cordoba 2006 of the second hand and I realize that it has three headlights in the lights apart from the flashing one, but of which only two light, when the brake is located on the two that are on the two that are on the outer side and when they go back to the inside of the inner side that are white but the medium never turns on, it will not be that it will not be activated or is it a bad connection? They could help me. Thank you
