Power problems Peugeot Boxer 2003
15 years 1 month before #13663 by manual-mecanica
Power problems Peugeot Boxer 2003 published by Manual-Mecanica
I have a Peugeot Boxer 2003, I try to keep it as well as possible, since it had a loss by a return of injury and not partia, I sent it to repair the injunctors and it has lost enough power, it costs a lot that it reaches the 80 -90 km/hour and then much more, I do not know what I can check if I go for a straight Recover the speed and in the slope loses the strength very fast.
In 1st.
What can I check.
Please help I am very complex for this.
15 years 1 month before #13680 by manual-mecanica
Manual-Mecanica Response on the Re: Power Problems Peugeot Boxer 2003
It is the Common Rail system maybe it may be the turbo or decalibrated the injectors
15 years 1 month before #13683 by manual-mecanica
They also tell me that the EGR valve can be dirty, that you think, the mechanic tells me for a long time, that we could do a maintenance of the turbo.
I await your opimnions
15 years 1 month before #13689 by manual-mecanica
You have the maintenance of the EGR that is one of the main causes of the lack of power, and then the turbo that is a bit more expensive, but I am a little intrigued because this happened to you after the injector, this was immediately later?
15 years 1 month before #13691 by manual-mecanica
If it was once assembling everything and going out to try it, I did not have much strength, but at 2 days later it was regular, but it does not have the same power as before, my query is how I can clean the EGR valve what would be the procedure to clean it, since here there are no services that do so, only would they change it for a new Common Rail incentors do not calibrate, this in an optional service to Bosch, which is unique that exists, apart from the Bosch, the Bosch service is quite expensive.
I hope you can help me to clean the valve EGR with my mechanic. If you can guide me how to do it.
I await your answer
