I have a Renault Clio 1.5 dci that at 110000kms by faults "of Factory" is broken the pipe that connects the fuel filter to the pressure pump of pressure and from there the big problem.
I change the food hose and I started, but I do not pass anything, nothing
and as I do not have Scanner, take it to a consent where they sent me by change
or did not attend me and took it to a mechanical center where they repaired it and they told me that I had the 4 bad injectors (as it is of the Common Rail type at the time that air enters the high pressure system, they burn these) Chile were too expensive and shods
the mount and schedule them and separate the pressure lift pump. He walked the engine, but not quite well the damn smoked more than Chinese smoking opio jajajajajaa and I don't get anything (less than 1000 km).
Now clean the injectors again and install and start the engine. The problem is that it costs more than a little starts, but emp finishing part instantly and with the sheet no.
Test with the tester the starting capacity of the battery (it has a new battery, CCA 600a) and at the time of starting the voltage low to 10.4 to 10.7 V and the engine does not work .... here is the story. When the battery with starting rises to 11 V and more the engine starts and works.
What should be? Will injectors or an electrical problem be?
I hope they replenish me as soon as I am more or less distressed since I also have a motito and I approached the raw winter of Chile
carefully Davishho
