Change the Hyundai Accent Clausor
15 years 1 month before #13758 by manual-mecanica
Change the Hyundai Accent Clausor published by Manual-Mecanica
Someone knows how the Hyundai clauses is disassembled. I have broken my key and half inside.
Grace for help
15 years 1 month before #13778 by manual-mecanica
Manual-Mecanica Answer on the Re: Change the Hyundai Accent closer
I would like to help you but I don't know what a closer is, if you tell me you can help you.
15 years 1 month before #13787 by manual-mecanica
where the key is placed to start the car. It turns out that when removing it, it broke and has stayed half inside.
15 years 1 month before #13797 by manual-mecanica
Ha ok, you have to disassemble the robbery cover is divided by the top I have lower, but you can ask a workshop where they make copies that take you the part that is inside, because to open the cylinder it is a bit complicated since it has some springs and insurance that if you disarm forget about putting them again if you do not know, but if you are careful to disassemble it, as I told you now you can Rivets that you will have to take with a sincel and a hammer, or when soldiers come to the axis, you must disassemble 2 insurance that they have below and an Allen screw that is in the superior part.
