Problems with the piston 1 in Toyota Corolla 97
15 years 1 month before #13782 by manual-mecanica
I am presenting problems with my Toyota Corolla Year 97, the fault is only presented when the car is cold, the piston stops working until the car is heated and maintained in perfect functioning until it cool again.
In fact, when the car is hot and for some reason it cools, that is, it goes down for a while or something the fault is presented again (only the fault is presented when it is cold) what can I do?
15 years 1 month before #13800 by manual-mecanica
Midele the cold compression, to discard rings problem
15 years 1 month before #13838 by manual-mecanica
I suggest that you take out the piston 1 candle, check how the electrode is to see how the cylinder is funeate if it is with carbon-aceite-limpiala and calibrate according to the owner manual and put it to work ..
Greetings from Honduras from Honduras
15 years 4 weeks before #13901 by manual-mecanica
It can be a cylinder injector that is dripping when you turn off the engine and bathe the spark plug
