Fiat Ducato Gasail Electric Pump
15 years 1 month before #13789 by manual-mecanica
Fiat Ducato Gasail Electric Pump Published by Manual-Mecanica
Hello. I have a problem with a Fiat Ducato that has Common Rail. Current does not reach the electric pump in the diesel tank. The fuses are all fine. Does anyone know where the breakdown can be?
15 years 1 month before #13827 by manual-mecanica
Manual-Mecanica Response on the Re: Electric Pump of Gasail Fiat Ducato
You have to look for what is the pump relay
15 years 4 weeks before #13885 by manual-mecanica
Look at the anti -impact inertial switch, this next to the battery.
You will tell me something
greetings
15 years 4 weeks before #13894 by manual-mecanica
Check the inertial interruptor may have jumped or the interrupted wiring
