It is covered by starting Picasso HDI 90CV
15 years 1 month before #13805 by manual-mecanica
It is covered by starting Picasso HDI 90CV published by Manual-Mecanica
Good afternoon in a Picasso HDI 90CV, it turns out for a month or so, that when the car starts at two or three seconds, the fourth time I managed to start it because today it happened again, it happens so cold with hot, today it did it in a semafaro stopped and calo three times the fourth I did not start.
time I wanted
15 years 1 month before #13831 by manual-mecanica
Manual-Mecanica Answer on the Re: It is covered by starting Picasso HDI 90CV
It can be the return of the injectors, I think that problem in the citroen
15 years 4 weeks before #13906 by manual-mecanica
When the return is turned off and does not turn on, it can be the low pressure pump or that has a defective injector, it can also be the turning sensor, greetings, the car scan the car.-
15 years 4 weeks before #13908 by manual-mecanica
Thanks for the answers was the bomb inside the deposit
