Spark front lights burn
15 years 4 weeks before #13869 by manual-mecanica
published by Manual-Mecanica are burned
Hi: Friends I have a problem with my Chevrolet Spark year 2008 are burned the front lights every week I have to change them, it will be a factory problem since in the street I see other cars of the same model and they are always with a burned light some atte suggestion
15 years 4 weeks before #13896 by manual-mecanica
Manual-Mecanica Answer on the Re: The spark front lights are burned
First of all what kind of bulb he carries and tries with a warm light bulb like Philips or Hella
15 years 4 weeks before #13903 by manual-mecanica
The same response and controls the land of them that are in good condition happened to me with a new land fiat and all fixed. Also make sure that the contact made by the brooch is good if it is wrong or is not, you have bad land and the vibration burns you
15 years 2 weeks before #14105 by manual-mecanica
You may have the battery load alternator that regulates above 15 volts, check the load voltage with the engine running with the tester, it has to mark
between 13.5 to 14.5V no more if the voltage is superior the problem you have in the alternator the most found the loading regulator. Ok
