I have some questions about Motor Setting
15 years 3 weeks before #13957 by manual-mecanica
Boy Acambiar the rings of my pistons but I found another problem my cylinders are a bit grated it will be that if they clean them to remove the scratches I can use the standard or nesec measure
15 years 3 weeks before #13991 by manual-mecanica
Manual-Mecanica Answer on the Re: I have some questions about Motor Setting
The measures SO 10 20 30 and Aveses 40 in center and connecting metal rings but to save the wear visually it does not have to have at the end of the cylinder the monoblok Another shape is with an interior micrometer or call the rectifier so that it measure it it will tell you if it endures or it is necessary to cut it to the other measure
15 years 3 weeks before #14013 by manual-mecanica
Hi Drago, if the scratches are deep, you have no choice but to rectify the cylinders because the hoops will not retain compression or oil rise, as for the measurement, do the fellow Orel924, luck and greetings. : Cheer:
15 years 3 weeks before #14015 by manual-mecanica
If you do not want to battle clean the piston hole in the top almost sympre says the measure of the ring if the s rayyas are very waves and if it is eyebrow the cylinder this will not work on the contrary you ask for polishing and putting a new ring
