P1895 Code at Astra 2001 1.8
15 years 3 weeks before #13959 by manual-mecanica
CODE P1895 at Astra 2001 1.8 published by Manual-Mecanica
Good afternoon ..
the car presents a fault since at the time of accelerating it in D it does not advance correctly.
In other words, it is gradually flight and then reaches its speed, so that the car works correctly, we have to handle it as if it were Standar [manual] 1, 2, 3 and d
put the computer and throw the codifo p1895 ... Does anyone know what kind of failure is it?
Thank you all.
15 years 3 weeks before #13994 by manual-mecanica
Manual-Mecanica Response on the Re: Code P1895 at Astra 2001 1.8
It is a cable like this or a selenoid that is not controlling and the code1895 you can get it out of the data that bring the scanner
15 years 3 weeks before #14022 by manual-mecanica
OREL924. You can please play me more in detail, since I have few mechanics knowledge ... Thank you.
15 years 3 weeks before #14035 by manual-mecanica
Why did they change the computer?
15 years 3 weeks before #14046 by manual-mecanica
Hello friends, Grios is correct, the observation is the good friend Orel ... if they scanned your car and if he had the ease of accessing feed ke is a good device and therefore I should have given you the description of the component that is failing ... if it serves you: Code P1895 Engine Torque Delivered Circuit. But it may not be correct for the model ... Check it with your mechanic.;) Salu2
