Hello I have a problem in my Stratus when I start it, it is turned on for a moment, like 5 seconds and turns off, check the signal in the injectors and the pulses of the computer are lost. It has no alarm and is not coded key. So I can't find what the problem is and this fault has me with a headache.
Czech if it brings Singor for this camshaft position and the crankshaft sensor directly act in the inlion and spark in case that is not that it may be landing the signal or the computer
