mechanical problem
15 years 3 weeks before #13962 by manual-mecanica
mechanical problem published by manual-mecanica
;) Hello. I have a problem with my Renault Logan 2006. Every time I accelerate, it does not respond and at least you think it starts as runaway. It was like this after I cleaned the air filter. I disarmed the cubicle where the filter comes to clean it and it was no longer the same. I hope you can help me. Thank you very much ;)
15 years 3 weeks before #13989 by manual-mecanica
Manual-Mecanica Response on the Re: Mechanical Problem
Well, the sensor that goes in the filter handles you air flow and so it has to do with what the revolutions are unless you share land with another sensor fix yourself in the filter censor if you do not break when cleaning it
15 years 2 weeks before #14069 by manual-mecanica
or it may be that this badly sealed and this entered after the MAF sensor mentioned by oel
