Help with fan
15 years 2 weeks before #14062 by manual-mecanica
Manual-Mecanica Response on the Re: Help with fan
306 and 206 are different in their electric design
15 years 2 weeks before #14063 by manual-mecanica
Hello,
what kind of motor? It is in the vin, for example: kfw, nfu ...
15 years 2 weeks before #14072 by manual-mecanica
Bridge the bulb if you have it if the electro is part of it is not a fault of relay or anything, also what you can do if the spare is very expensive is to make a parallel installation to the electro with a relay a fudible and cable, it is not very complicated you put a bublbo of any car the cheapest and already solved, it is easy and practical I am very appropriate.
15 years 2 weeks before #14077 by manual-mecanica
Yes and no ..... I would have to make sure you have no other electrical problem; At least I should make a reading of the BSI to locate the problem safely.
15 years 2 weeks before #14104 by manual-mecanica
In Peugeot Remove the engine of the fan right side on the feet, remove three screws and motor and set resistors OK.
