Nissan distributor
15 years 3 weeks before #13984 by manual-mecanica
Nissan distributor published by Manual-Mecanica
I would like to know what tests are owed to the optical censor of the Nissan distributor to know if it serves
15 years 2 weeks before #14067 by manual-mecanica
Manual-Mecanica Answer on the Re: Nissan Distributor
It depends on the doubt you have, if the distributor throws spark is the first if everything does well, you can check if the electro magnet is magnetically loaded, if its internal resistance is fine, and if it cuts the field when turning.
