A query there if someone knows how to tell me, I just bought a Peugeot Partner 90 CV HDI, you would know if modifying the PROM, additional power could be achieved, the two engines of both the 90CV and the 110CV are the same or the lubrication is reinforced in the 110CV.
Hi Pacovillalomin, I don't know if I can satisfy your consultation, but I could clarify something. From 90cv, the 90CV power is more direct and in 110cv it works more progressive. OTHER THE OTHER AND THE TIME PUSHING THE CULAZO I CHOOSE 110CV. If you want to raise power ... think it is 1.6 and without touch -ups in the turbo, there is no more.
Well thanks for responding, but the additional power is not given by the variable geometry turbo, the variable geometry prevents the overpressure of admission in high revolution, the additional power of 90 to 110 should give the increase in injection with the same cubic (1600) Thank you anyway we will continue to investigate.
