Good morning to see if someone can help me, it is the first time I change the oil to my nuance, in principle everything VAT well, remove the screw from the bottom the plug and the rod and change the oil filter, when I fill it I realized that it fills it more and now comes the problem, I remove the plug from below and not fall at all or cold Another plug around if you can help me greetings
If engine oil does not come out because it does not have, but it is easy to save the engine purge screw goes in the carter, there is no more, and the box then in the box, if the oil you took has a smell like almond then is cash and not motor.
