H100 2.5 Diesel Engine not part
15 years 2 weeks before #14125 by manual-mecanica
Diesel Motor H100 2.5 Not part published by Manual-Mecanica
Hello and congratulations on the page.
Buy an H100 2.5 diesel engine without diesel pump and install a 2.5 mitsubishi engine pump (they would tell me that it was the same but this does not start) will it be a problem of the pump that does not correspond to the ignition order or synchronization?
15 years 2 weeks before #14156 by manual-mecanica
Manual-Mecanica response on the Re: Diesel Motor H100 2.5 No part
The pump is the same the mitsubishi L200 and the H100 are the same, check the draft and the bleeding of the system
