VW 1.8 T gasoline, when when he has a hell
15 years 1 week before #14247 by manual-mecanica
VW 1.8 T Gasolina, stands out published by Manual-Mecanica
Hello, I have a problem with a Passat 1.8 t gasoline, starts very well and marches in relief, but with nothing to play the accelerman stops immediately. I have changed the entire engine (the injection too), and follow the same thing, does anyone know if you have any gasoline filter that is stuck or will it simply be the gasoline pump?
15 years 4 days before #14310 by manual-mecanica
Manual-Mecanica Answer on the Re: VW 1.8 t gasoline
It is lack of gasoline, or it is your pump, its prefilter, the ppal filter. or the peaks
15 years 2 days before #14332 by manual-mecanica
Hello, it is already solved, it was the butterfly valve, I have a friend who has a diagnostic machine and has stressed that valve. Greetings
15 years 2 days before #14334 by manual-mecanica
What luck friend, ah I work for motorcycles and if you know someone who has a Suzuki TS200R workshop manual, I will be grateful for it
15 years 2 days before #14339 by manual-mecanica
Pois sorry, but I don't think I can help you, here in the town I know one who repairs motorcycles but the uncle is not very pleasant ...
