Ford Fiesta RS Turbo.Fallo Motor Da Saltos
15 years 1 week before #14270 by manual-mecanica
Ford Fiesta RS Turbo.Fallo Motor Da Saltos Published by Manual-Mecanica
I have a RS Turbo Ford and a failure has left the engine suddenly, I explain it: when walking goes perfect, but when the turbo begins to put the car the car begins to jump as if it took his foot from the accelerated and accelerated again suddenly, he only does it when the turbo begins to blow if I carry it without the turbo worse does not fail. I close contact and start again it is removed but it comes out again, I have tried everything and I have changed pieces of another car that I have the same does not fail and I do not take it away.
15 years 6 days before #14307 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Fiesta RS Turbo.Fallo Motor Da Saltos
Valeriano Lopez wrote:
I have an RS Turbo Ford and a failure has left the engine suddenly, I explain it: when walking it goes perfect, but when the turbo begins to press the car the car begins to jump as if it took the foot of the accelerated and accelerate again suddenly, it only does it when the turbo begins to blow if I carry it without the turbo worse does not fail. I close contact and start again it is removed but it comes out again, I have tried everything and I have changed pieces of another car that I have the same does not fail and does not take away.
8 years 2 months before #52204 by manual-mecanica
Well, although the post is a lot of time ago, I will answer the same.
What happens to you is because you have the turbo "blowing" at excessive pressure. The Turbo party comes with a serial pressure between 0.5 and 0.55 (0.6) bars. Having excess blossomed, the MAP (Manifeold Air Pressure) probe, detects an excess air pressure in the intake manifold (surely that turbo was blowing more than 0.8 bars, which I think is what the MAP comes to) and the switchboard enters "safe" mode and begins to cut injection as engine protection. You have to be careful with these things because having the turbo blowing the beast, you are chopped with connecting rod (the explosion in the cylinder occurs when the piston is still in the ascending race towards the PMS). You load the engine in less of anything.
Greetings, seven years late.
