SOS Hyundai H-100 (Porter) fails to heat
15 years 4 days before #14306 by manual-mecanica
The timer's time is very short, the spark plugs are not heated. The timer works through the water temperature sensor (resistive) but this sends the signal to dough when the engine is already hot and I remain without activating reluctance of the spark plugs and without strength for the start. I hear it could help me, or know the electrical diagram. Thank you.
15 years 3 days before #14326 by manual-mecanica
Test with another timer is very likely that he has been out of control (that is, the module of the heater)
15 years 3 days before #14328 by manual-mecanica
Change for a new timer and a new temperature sensor ...... The sensor reaches food and internal resistance goes out to timer's time control, but when the motorya is hot decreases the internal temperature of the tempo sensor. And makes the other exit the signal to mass annuling the heater and the forces Pal starter motor ???
15 years 13 hours before #14364 by manual-mecanica
But when the engine is already hot, the heater do not have to enter and this is common in a large number of vehicle brands I have had to wait for vehicles to cool to test the operation of many heating circuits
14 years 11 months before #14395 by manual-mecanica
Of course, when it is no longer in, the problem is that the temperature sensor has internal resistance by being hot makes zero mass resistance and sends the current to ground when starting ???
