My car does not go from 50 km/h
14 years 11 months before #14368 by manual-mecanica
My car does not go from 50 km/h published by Manual-Mecanica
Hello colleagues, I have a Dodge Viper that does not go from 50 km/h, the problem is that it does not accelerate anymore, they have told me that the problem can be the flow or meter of mass of air and I would like to know if someone can give me their opinion, the compressions of the car are fine and tomorrow I will check the ignition system, if someone has the manual or can tell me where to find it would be incredible since it is not a way.
14 years 11 months before #14382 by manual-mecanica
Manual-Mecanica Answer on the Re: My car does not go from 50 km/h
Look like your car is governed at that speed and certain revolutions disconnect the speed sensor to verify, now it can also be the scaling sensor or if it brings TPS can also be the cause.
14 years 11 months before #14404 by manual-mecanica
Hello, you do not mention whether the vehicle responds well or with the stopped vehicle responds to the acceleration, I think you should check the vehicle clutch system. Hopefully you can solve your problem, Chao.
14 years 11 months before #14844 by manual-mecanica
Hi ... have you checked your gasoline pump?
or you may also be due to your catalyst ... this covered ..
luck;)
14 years 10 months before #15031 by manual-mecanica
Hello, if it can be the caudalimetro, but if it has intercooler it can also be its failure.
greetings
