Hello friends, I thank you for your contributions, again withdraw the time band and the points were reverified on the Sigual and camshaft and they are corctus, as I tell you the hall or ignition sensor, again, take off the distributor The same, what we notice is that the distributor does not fall well is a bit raised as it does not feel good in the engine wedge, but if the rotor may turn through the rgrane that I rotate it and not because of the wedge today I will disarm the distribution to see if it is having well in the wedge or not perhaps this is the problem or the sensor that I buy this bad is also new. Taking advantage of the fact that time has already improved (Hurricane Alex spent) greetings.
