Problems with my Daewoo Lanos 1.5
14 years 11 months before #14478 by manual-mecanica
Problems with my Daewoo Lanos 1.5 Published by Manual-Mecanica
Hello everyone, I have Daewoo Lanos year 2000 1.5 Automatic for several months a fault has been presented and I no longer TCM which is the transmission control module but the Scaner says the above, the fault is presented more often when the a/a off but when I turn it up, it sometimes calms down sometimes shorter others longer. In that you can help me that they believe it is supposedly the TPS and I have no longer changed the IAC also the bobona is as new the battery is new the Alt. Removed no longer where to look for
14 years 11 months before #14511 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with my Daewoo Lanos 1.5
I believe that the whole problem is in the gearbox, the light that turns on is of the motor failure, however checks the put -in -law and give a little torque to the Damper Aver bolt if this bolt is quiata in Daewoo bothers a lot especially with the angle of Avanse, and this failure is prevented by many GM models. Czech and warn, your butterfly has not been intervened, right? that is, not the hand regulated to improve the release?
14 years 3 months before #20214 by manual-mecanica
Brother I have the same problem only that mine is presented more when I have the A/A ignition, I do not know what to do they did not tell me that it could be the parate/neutral sensor. MY LANOS IS 1999 1.5 AUTOMATIC.
14 years 3 months before #20215 by manual-mecanica
If you get the solution, let me know please ... B
14 years 3 months before #20222 by manual-mecanica
Anta everything greetings my corduroy will be that the man's manual would pass it to me or you would say where I could download it to revive the car with more detailed, and I agree with the comment of Q is the box apply a reset with the scan
