Nissan Athleon
14 years 11 months before #14493 by manual-mecanica
Nissan Athleon published by Manual-Mecanica
Hello, I have a Nissan Athleon Year 2008. 4500cm3 at root that the witness of the battery and the alternator are on, check the load of the alternator and did not carry. Replaced the alt. And I check it with an electrician and I suggested changing it. Now with a new alternator follow the same problem: do not load the battery and the witness on
14 years 11 months before #14494 by manual-mecanica
Manual-Mecanica Answer on the Re: Nissan Athleon
You have the fuse badly. Look if the brake lights function but I think not (it is a fuse of 10 a)
14 years 11 months before #14503 by manual-mecanica
Hello Ivano, the partner is right, check the safe fuse well, greetings. : Cheer:
14 years 11 months before #14613 by manual-mecanica
Thank you very much colleagues.
