Box of speed or manual passenger
14 years 11 months before #14583 by manual-mecanica
Box of speed or manual transeje published by manual-mecanica
I have a sound in the manual passenger of a neon 2000 model car and when brake also sounds a Tac Tac Tac. And if brake hard does not sound the TAC TAC. The sound of the passex is when it is in neutral position when I start the clutch vibrates a little ,. It will have something to do with the sound of the two parts the vibration. Check the tripoid or transmission axes and stam in good condition that may be
14 years 11 months before #14589 by manual-mecanica
Manual-Mecanica response on the re: speed or manual passex
If it sounds in neutral it is not a problem of any component of the axle, nor of the front train, if your car is mechanical testing the clut
14 years 11 months before #14770 by manual-mecanica
Aja, the car sounds in neutral and when the rmbrague is removed the noise takes
14 years 11 months before #14778 by manual-mecanica
Then it is a bearing of the speed box you have to lower it and open it.
