4G15 Mitsubishi Lancer Motor Compression Factor
14 years 11 months before #14585 by manual-mecanica
Hello everyone. I just bought a Mitsubishi Lancer of 2006 Motor 4G15 SOHC (1500cc) No GDI. I am interested in knowing what the compression factor is, since this information is vital to know exactly what level of octane must have the gasoline that survey. I am currently beating 90 octane gasoline, ensuring that it is spring or another of good quality. The car works in the most good (not dull) and has a good power, but this could be due to the fact that as is full inject, the ECU, efficiently regulates the ignition process. It would be good if any of you, has a table of compression factors vs. Octane. Thank you!! :)
14 years 11 months before #14591 by manual-mecanica
Manual-Mecanica Response on the Re: 4G15 Mitsubishi Lancer Compression Factor
I do not have table but that engine with 95 octans is super and is what the manufacturer is recommended. without lead logically
14 years 11 months before #14598 by manual-mecanica
Thanks, I'm going to take it into account.
14 years 11 months before #14608 by manual-mecanica
Hello, I would tell you that you use fuel 95 or 97 octane the motor cup relationship 4G15 12 electronic injection valves is 10 to 1. greetings
