Climatizer only works when I go on the road
14 years 11 months before #14626 by manual-mecanica
Climatizer only works when I go on the road published by Manual-Mecanica
Thanks in advance, I tendo a Scenic 2.0 dci the air conditioner throws cold air only when I go on a road or a speed of 70 km onwards. When I go through the city or I stop, I don't take cold air. I have checked the load and it is correct already those speeds works perfectly. That can happen to him. Thank you I wait for your help.
14 years 11 months before #14629 by manual-mecanica
If it works only at that speed I lean to the option that you are only receiving air from the outside as if you had aviert in the control panel the option or figure of an arrow that enters through the hood inwards, and that the air does not work indeed and it is not there is that speed that makes it. Remember that air only works with closed glass.
14 years 11 months before #14631 by manual-mecanica
Look if function. condenser fans
14 years 11 months before #14843 by manual-mecanica
Hello good ...
you should check your compressor maybe this breakdown ..
