Chevrolet Astra with temperature problems
14 years 11 months before #14654 by manual-mecanica
Chevrolet Astra with temperature problems published by Manual-Mecanica
Hello, I am new here, I have a chevrolet astra 2001 1.8 Andube a few days with little asth cooling water that stopped only the car (as they tell me the car stops only to avoid a greater evil) the thing is that now it works correctly until it warms and stops (I already throw water) but they tell me that it can be since I want to throw the engine thank you...
14 years 11 months before #14658 by manual-mecanica
Hello friend, check well the thermostat that works properly and that couples the electro -ventilator well, in terms of the failure you comment to scan to get the doubts, it is something difficult to predict when you do not have the car at hand, greetings. : Cheer:
14 years 11 months before #14660 by manual-mecanica
Ok friend, I thank you, they seemed to me that the theme of the thermostat is going there, I already took it out and apparently it is stuck but I will scan it, thank you very much
14 years 11 months before #14724 by manual-mecanica
hi how are things.
What I can tell you is that perhaps you are confusing one fault with the other. If you walked with little water in the refrigeration system and this is the cause of a failure you must have reflected in the temperature sensor of the board should rise a lot, which you have not named. If you allude that the fault can be an engine reheating you have to present other symptoms to think about example, high water temperature revalue from water due to Spanish pond and already more serious the engine does not start.
What I think can be the failure that happens in these vehicles is the ignition module this presents a symptom as you name it, the engine starts well but on certain occasions it stops, you wait for a while you turn it on again and part again and then it stops again.
Verify it and tell us results
14 years 11 months before #14835 by manual-mecanica
The truth is already changing the thermostat and the fault is maintained, now I go for the electric part, I ask you to help, I already take out the coil to buy it but I also want to change the ignition module but I do not know where it goes and how it is ... there I ask them to help me and tell me if it is very difficult to take it out. thank you so much
