It is cencillo with some knowledge, if the Marcala distribution is tuning so that the point is not lost, it takes the strap loose everything that aya that releases and releases the butt bolts that are under the multiple change the packaging lings well the surface and put the new Czech that is not crooked the cylinder head and put it, give the torque corresponding to the pores in the correct order.
