A Z24 cavalier takes to light
14 years 11 months before - 14 years 11 months before #14792 by manual-mecanica
A Z24 cavalier takes to light by Manual-Mecanica
Greetings friends.
I have a Z24 Cavalier, it takes for it to turn on, the morning for me to get a faster one, it is that I have to give it several times for the start (for the suiche) after several attempts but with short touches, after ignitioning the car works to me wonderfully does not have any other fault.
In opportunities I pretend to touch but when Leda chasses it. I have that fault for more than a month, Pence was the pump but this has pressure.
Last edition: 14 years 11 months before by .
14 years 11 months before #14796 by manual-mecanica
Manual-Mecanica Answer on the Re: A Z24 cavalier takes to turn
If it is the cavalir with a Bosch Tenperature sensor, change it and already, in general the GM engines give a lot of can with this sensor cost to leave sometimes they pull, it is not a spare face, or take it out and measure it with a tester.
14 years 11 months before #14797 by manual-mecanica
Thank you. I had no idea that it could be. This sensor is the one that measures the engine temperature? What is in the pipe?
14 years 11 months before #14812 by manual-mecanica
If it is two cables, it is for clock
