Help Chevrolet Luv 96
15 years 1 week before #14803 by manual-mecanica
Help Chevrolet Luv 96 posted by Manual-Mecanica
Hello everyone:
I need help with my truck, it is a Chevrolet Luv year 96 2300cc, the problem is the following, this state truck stopped around 2 years, because it simply does not turn on, and reviewed injectors, the injection pump, coil and spark plugs, they have told me that it can be a purely electric problem, change the computer that was burned by a new one but still the same.
A fact, by placing fuel for the multiple of admission leaves without any problem, but only lasts the benzine that I put.
I really don't know what else to do, I'm going to try the computer's electrical cables to sensors and actuators to see if there are problems.
Finally a consultation. Does anyone know that sensor allows the non -ignition of the engine?: HUH:
15 years 1 week before #14804 by manual-mecanica
Manual-Mecanica Response on the Re: Help Chevrolet Luv 96
Hi Andres.
To start with a small introduction, I can tell you that for a car with electronic injection to turn on, it must have four main conditions.
1.- Fuel
2.-Aire
3.-Chispa
4.- Pick up sign
so you comment apparently you should not have air or spark problems due to giving it direct fuel lights.
Then you can focus directly on the fuel system and pick -up signal. When giving contact you feel the pump in the pond? Or when you start that you work? If it does not work directly when starting. This is in the pond and energizala from the relay to verify the condition of the wiring. With this you can leave if it is not resolved we will inspect the signal sensor signal. Informen
luck...
15 years 1 week before #14807 by manual-mecanica
Ok because of the prompt response, I will try the sensor you mentioned, having what happens, the pump is working, also verifies that it comes with enough pressure to the injectors, the problem is from there, something makes the injectors do not work.
I will have the sensor theme, comment on the results.
15 years 1 week before #14809 by manual-mecanica
hello.
I understand that you have the clear idea. Most likely it is the signal of the crankshand The 12 volt are always present because the injectors switch by land that is to say with the mass cable.
luck...
14 years 11 months before #15117 by manual-mecanica
Hello Victor, I tell you that I could not find the sensor you mention, I went to a Luv spare parts store and they told me that I did not exist, so I return to zero. By chance you will have the manual of this engine (Luv 95 2.3 cc) I would be useful, I would appreciate it, since I have 2 of these trucks, and take them to the mechanic where I live it costs me a lot of money :( .
