starts and turns off
14 years 10 months before #14933 by manual-mecanica
starts and turns published by Manual-Mecanica
I have a 2000 jetta and turns off after 10 sec, and with the vag I marks the P1570 code blocked engine module
14 years 10 months before #14952 by manual-mecanica
Manual-mecanica response on the Re: starts and turns off
Hey you have to change the module. I recommend that you go where they program keys you could get it.
luck. It's all you have not spent on looking for another fault that is not
14 years 10 months before #14976 by manual-mecanica
If you have another key prove with the other key to see how it walks, because those compus are often blocked.
