2003 tracker
14 years 10 months before #14946 by manual-mecanica
2003 tracker posted by Manual-Mecanica
Good afternoon, someone can help me to take advantage of the 2003 tracker's speeds, I do not know when you should use the "O/D OFF" button, which is located on the speed lever.
14 years 10 months before #14954 by manual-mecanica
Manual-Mecanica Answer on the Re: Tracker 2003
Ola that is the over Drik
serves if you go on a climb, the truck is slow ... (a focus or lever is turned on on the board)
OPLARD I FEEL THE RETROSEZO OF VELOITY ..
THAT WHAT IS OF 4 RETURNS TO 3rd ...
OR 5 TO 4th Speed!
It is the same in a disarming down ...
It would be the engine brake low a speed so that the car does not go so relieved.
I hope you understand me xD!
but then ask again.
see if t serves ..
zales
: Woohoo:
