BREAK DISTRIBUTION BELT IN R-21
14 years 10 months before #15088 by manual-mecanica
Manual-Mecanica Response on the Re: Break Distribution strap in R-21
Friend it is best to install the distribution strip will serve the vavular distribution well and the distributor then turn it manually to verify that it does not at any time locked once you will surely give it start to verify the operation. I wish you luck.
14 years 10 months before #15109 by manual-mecanica
If you put the belt with the point well placed, and nothing will happen if it is well tuning, now about two laps is always turned to make that the valves are not touched, in the worst case if there are valves folded the release will be irregular, the pulley can be released with paciensia and avility as you say but you can Autodata distrusted me in this computer so I get it from work and I pass it to you.
14 years 10 months before #15121 by manual-mecanica
Thank you so much.
As soon as I receive the diagram that you tell me, I get down to work.
14 years 10 months before #15161 by manual-mecanica
here is if you can't see it send me your email for
ATTACHING FILE:
File name: distrib_r_21.doc
File size: 157 kb
14 years 10 months before #15251 by manual-mecanica
As you have already told you what you have to do first is a new belt and hear the distribution well, try to put it out and see if the valvuas have been damaged if they have been damaged to take out the butt.
