Spark plug calibration
14 years 11 months before #15128 by manual-mecanica
Spark plug calibration published by Manual-Mecanica
How such friends from mechanics, I want to ask them a question. I just bought a First 2007 Fiesta 1.6 engine and I want to do your service and the question is, what is the spark plug calibration measure? to have your performance and optimal power. I appreciate beforehand to start space and to finish your help greetings to all.
14 years 11 months before #15135 by manual-mecanica
Manual-Mecanica Response on the Re: Spark plug calibration
mmm the spark plugs usually come calibrated from factory or do you want to give 0.40 mm of light between the electrode. Now if Kres higher performance, put some spark plugs of 3 or 4 electrodes, obly come out a little more but they are much better. greetings I hope you have been useful
14 years 11 months before #15159 by manual-mecanica
For the party, the calibration is 1.3 mm, 0.40 mmm is very little s almost serrated, and only spark plugs of an electrode of two of three of three of the performance is not true, they are known with the name of high -unrepenting spark plugs, in reality they are not very practical is more Powerful, now remember that the seacual spark plugs are just throwing a spark those of two untas 3 or 4 equal only one spark only that they have more roads where to jump, luck and greetings.
14 years 11 months before #15247 by manual-mecanica
The "no" spark plugs are calibrated of factory, since a type of spark plugs is for many types of vehicles of different brands, I suggest that you check your owner manual or Internet lows the catalog of Bosch spark plug, you will find the spark plug calibration of almost all known vehicles from 80s onwards. Now if you want to put spark plugs, three, or four electrodes you can approach, it has nothing to do with the power of the spark of your vehicle, the difference will be that these spark plugs will last longer since the spark runs through the most next point therefore there to last more those of four electrodes than that of an electrode. Its resistance is not greater since the spark looks for the shortest path and with four electrodes the spark has more options.
14 years 11 months before #15249 by manual-mecanica
If you put new spark plugs come the regulated factory electrode, do not entangle to tangle that you will complicate your life.
