Aztek crankshaft position sensor
14 years 10 months before #15316 by manual-mecanica
Manual-Mecanica Answer on the Re: Aztek crankshaft position sensor
B) oks any questions I'll consult you ;)
14 years 10 months before #15348 by manual-mecanica
It brings it in the back to the middle of the monoblock almost arriving at the carter I hope and are talking about the engine that is the same as the Malibu :)
13 years 1 month before #34848 by manual-mecanica
This is how it comes in the back of The Alamitad engine above the Cartes Board Ahi Checalo and if it is the same engine as Malibu
13 years 4 weeks before #34856 by manual-mecanica
Do not batalles brother fits the car safely since it is blocked with its respective towers and hand brake on the bottom of the engine and locates the crankshaft pulley and you will find it is easier, since its own name says it is a fisheñal position sensor
8 years 6 months before #51808 by manual-mecanica
Manual-Mecanica Answer on the Aztek crankshaft position sensor
It is located at the back of the engine, to the right of the exhaust pipe, very difficult to access. You can see it for a slit between the oil crankcase and the oil box of the speed box. You have to disassemble the middle part of the escape to reach it, there is also another sensor behind the crankshaft Damper pulley.
