Centralized closure
14 years 10 months before #15233 by manual-mecanica
Centralized closure published by Manual-Mecanica
Hello everyone I have an astra 1.7 CDTI year 2004, I would like to know if this model when you go, you can do something to block the door, without having to give the button of the inner console, I have heard that it can be activated ... but I do not know how
thank you very much and a greeting;)
14 years 10 months before #15273 by manual-mecanica
Manual-Mecanica Response on the Re: central locking
As I understand it depends directly on the alarm and the type of closure. It is a kind of tenporizer that activates but I am not 100% that can be done in a car, just modifying and not adding extra elements, for the cost I do not think it is very bad idea to continue tightening the button.
14 years 10 months before #15304 by manual-mecanica
It was simply in case it could be done ... anyway we will continue with the button.
Thank you so much;)
14 years 10 months before #15366 by manual-mecanica
Your car has the comfort system if so in the owner's manual I should tell you how it is done and if it is possible.
14 years 10 months before #15371 by manual-mecanica
In the book that comes, it makes me pre -closing the console button for 3 second, then unlocking the doors with the key control and it is assumed that at 5 minutes the closure of the doors alone should be closed, but I have tried and does not work.
Thank you all, I will read it again;)
