Motor failure
14 years 10 months before - 14 years 10 months before #15491 by manual-mecanica
Motor fault published by Manual-Mecanica
The 3 cylinders of the left head do not work apparently there is no spark ... the spark plugs came out full of gasoline ... can the camshafts turn away? Does anyone have the time diagram?
Last edition: 14 years 10 months before by .
14 years 10 months before #15498 by manual-mecanica
Manual-Mecanica Response on the Re: Motor failure
First or they are spark plugs or the valves of the cylinder head do not serve and there you have the fault :)
14 years 10 months before #15499 by manual-mecanica
What can be done? Thank you
14 years 10 months before #15501 by manual-mecanica
hi how are things.
As consultation, after this fault you have verified the conditions of the spark plugs that fail you?
Do you have any spice color or condition?
14 years 10 months before #15515 by manual-mecanica
First do not start buying spark plugs remove the cylinder that according :(
