As or "what do I do"
14 years 10 months before #15533 by manual-mecanica
Manual-Mecanica response on the Re: as or "what do I do"
You checked when the fault does if the coil recive current to the connector, there are coils that heat and dilate and cut the current, the same goes for the captor or crankshaft sensor
14 years 10 months before #15534 by manual-mecanica
I forgot, your truck has a flow or is it the one that does not bring?
14 years 10 months before #15589 by manual-mecanica
Ok. Thank you Jose Juan, I will continue to try the next step is to get the electrical diagram to consult it with a friend since I do not give that bouquet very good but we will be in communication to see how this situation ends I thank you for your attention "Greetings"
14 years 10 months before #15590 by manual-mecanica
14 years 10 months before #15592 by manual-mecanica
Kikemec I really have no idea if it has a flow but I invest it and if I check the connector and there is no voltage when the failure is presented and put on a test lamp on that line and while the engine works the lamp is flashing and once it fails there is no current and at the beginning use tree sensor and that of the crankshaft to activate the signal and nothing although I do not comment. Electronica does not give me a friend who is dedicated to the electric one but I have to get the diagram and keep trying thanks and greetings
