Thank you for your contribution and advice, I will tell you that new valves settled and seats were rectified, the original fault of this jeep was that he was working well arriving home and did not want to turn on anymore, although he already had a problem with a burned valve that was the one that opened more, he was cool, everything was electric and it was fine, he proceeded to check the distribution chain. Marks, I change it and I do not start the engine, notice that the compression went up, down and send a rectifier to do the necessary work before mounting is checked to settle valves well, but not even, it will be possible that this fault can cause the carburetor ???? Since when they remove spark plugs they come out wet from gasoline! Thanks friend, good Sunday!
