First you must find the problem in the distributor, one of the most common problems is wear on the distributor axis bushings which must be corrected with the change of bushings, these bushings are usually made on a measure. Another problem is because of the colorful plaque or electronic ignition, these two are achieved in the refactionary, personally I recommend that you change the distributor, since this saves you time and a total guarantee.
