carburetor
14 years 9 months before #15768 by manual-mecanica
Carburetor published by Manual-Mecanica
Hello, I have boys with the car, see if someone can take a hand. Which one is short, in workshop I put a stick that you do not see, 400-500E, I wait for your answers and tips, thanks, greetings. :( :( :(
14 years 9 months before #15774 by manual-mecanica
Manual-Mecanica Response on the Re: Carburetor
You must first verify if the butterfly is making ground and replace all damaged wiring. To verify if you are making ground you must do the following: place a cable making contact the butterfly connector and the other end has the positive battery positive.
14 years 9 months before #15798 by manual-mecanica
I have a question how do you have carburetor with a butterfly sensor? Is it carburated or injected? or mono point, which looks like a carburetor with a setral injector? Anyway, the shorts in cable go through sircos generally a sirwy is damaged, I think you should look for the cable with the problem and replace it, or try to change the connectors when they make bad contact fail and burn
14 years 9 months before #15841 by manual-mecanica
Good I have a Hyundai Excel 1.5 98 Carburado has problems with the air mixture Air gasoline is burning a lot
