I have a problem with the sound of my vocho's aim Straps since when you start you sound as if they were not calibrated and you already calibrate them one and give cleaning to the thrust barrels, also to the rocker bar and its arteries that were a bit covered by the dirt that is formed by normal use.
Already using it the sound is elinine but I am worried that the Sonidi is a bit strong and even the bench sounds a bit I am thinking of changing the oil pump because when it uncovers and calibrates the aimers to pull it and I saw that it does not irrigate of even oil in one of the aprons and are the ones that sound.
I also believe it is the dumps but I think they are mechanics not with spring like the Fords that are damaged very fast in a 302v8 I hope someone can help me since I have been about to remove that pump I already did it in another mouth and if it felt a little better but this was of a caburetor and I was already very old but with the 90 -engine 90
If they are delayed in lubricating and are not with hydraulic taquis, it can be as you say your pump but I do not believe much, because it has only one pump for both sides and only one sounds, what can happen is that the pipelines or oil ducts are clogged.
