When the cylinder head is removed a RAV4 2002 engine must be replaced chain tensioner and when time is lost in this twist Valves in which way the tensioner should have while it is disarmed
Aver are different things that you speak, to get the cylinder head you first take to the draft and there It is to move the vehicle without chain and with a cylinder head, and when you put the cylinder head, you will set it to install the ratatoines are in the midst of the cylinders not to give valves with the PARTE.
