The air conditioning goes out every time
14 years 9 months before - 14 years 9 months before #15835 by manual-mecanica
The air conditioner goes out every time published by manual-mecanica
It has the pounds of perfect gas and by the way it is a daewoo nuance year 2000 and the electrical system says that it is fine but I see that the Relex del Romilera is heated a lot that I do: Blink: I need its help
Last edition: 14 years 9 months before by .
14 years 9 months before #15840 by manual-mecanica
Manual-Mecanica response on the re: air conditioning goes out every time
Hello, if your model has an auxiliary electro -ventilator for the air conditioning, it can be this one that causes overconsumen, the truth that an air conditioning does not have many electrical parts, only the electro, the coupling clutch, seek consumption between these two.
Try to tell me specifically that it is heating.
luck
