305 ray cover engine help
14 years 9 months before - 14 years 9 months before #15857 by manual-mecanica
305 Rayada Tapa Motor Help Published by Manual-Mecanica
I have a 305 scratch cover is full injection use carburetor, the gasoline pump that wears is electric and I want to change to a normal pump because the electric is very damaged my question is can I change the camshaft that has a camshaft that has the cam for the pump?
Last edition: 14 years 9 months before by .
14 years 9 months before #15868 by manual-mecanica
Manual-Mecanica Answer on the Re: Motor Help 305 Rayada Cover
You can but you can buy or make the bomb connection with the cylinder head
14 years 9 months before #15870 by manual-mecanica
As I do that connection I already have the mechanical pump, they told me that it is necessary as a kind of pencil, is that the connection that you say?
14 years 9 months before #15909 by manual-mecanica
This is the part but works lubricated with oil and moves to the pump so that Chupe gasoline is usually booked next to the cylinder head for the most serum to carburetor.
