How about friends, I hope someone can advise me with this problem I have with this car.
SYMPTOM: The car works correctly in Readi (in low) and if we do it little by little it does not have problems, but by accelerating it faster the engine tends to go out and this causes it to lose the Fueza, the engine.
The following was reviewed:
1- Compression of the pistons, is within the specifications.
2- It does not present fault codes in the ECU
3- The owner of the car had already changed the gasoline bomda, currently has 40psi
4- Check the MAF sensor (voltage) and apparently it is working properly.
Friends, give me a track, since I am about to throw in the towel, greetings and thanks in advance for your time
